flooring over garage floor
25 Aug 2004
Cornwall
we have a long garage and the rear 1.8m are dedicated to our laundry equipment and a freezer
my wife wants to have it tidied up to make it easier to clean
i envisage fixing something to the concrete slab to give a clean and flat substrate and then using vinyl tiles to match the kitchen flooring which is vinyl planks..
there normally isnt any water on the floor except when i occassionally check the washing machine pump and get a little flood.
any suggestions please...especially on the fixing to the garage slab..
cheers
geof
Hammer fixings through wood?, but identify and avoid piercing any damp proof membrane below the concrete slab.
Cheers,
Blup
Cheers,
Blup
I would drill the slab for rawlplugs and fix the ply with screws
The plugs will be the brown size, as to not go too deep into the slab surface
Cheers
GEOF
Hi again
I have the plywood in position now and have thought concrete self tapping screws might be a better and more effective than plugging.
When I come to drill the fixing centres, do I need to use a wood drill bit to go through the 5.5 plywood or will my masonry bit be ok?
Cheers and thanks again
GEOF
How old is the garage. Does it have a dpm under the concrete. If not plywood isn’t a good idea.
You be better using a latex screeding compound.
Have you looked at interlocking rubber / pvc Tiles. Great for garages.
SEE MY NEXT POST AS WELL
I can see the dpc coming up the sides of the concrete, the house is about 26 years old
And brilliant idea those interlocking tiles, but not in my budget.
The plywood is only at the end of the garage in the utility area...later I plan to use garage paint on the rest of the floor where the car sits
I use that area as a workshop too when the car is out in the driveway
I have had ply down for a year temporarily and lifted it up to put the new plywood in, its dry and unstained on the underside
Hope that helps
Cheers
GEOF
I just have. Interlocking foam for gyms and playrooms at 26.99 for 48 sq m. Just the area I am doing..
Are those what you were referring to...seems better
Cheers
GEOF
