My parents house built around 1980 .... has a living room, to which was added a small extension both parts have solid screed floors.
Currently has a pretty awful laminate floating floor laid over it, there is a definite ‘hump’ as you move from extension to main room.
This is at 90 degrees to plank run.
Going to need to relay flooring ...will add a 3mm underlay to try and help even out .... Q is whether fitting a Vinyl plank flooring might be better for this than laminate ?
