I am needing to add a 3rd outlet but can only find traps with 2 connectors, but then I found this http://www.screwfix.com/p/floplast-hose-connector/48625. here is a picture of it on a fitting http://www.screwfix.com/p/floplast-appliance-trap-adaptor-white-40mm/11180
If I got the outlet in the first picture will I just be able to use it on a 40mm compression tee, so cut into my 40mm pipe as it gos straight from the trap to the outside and put in the tee and add the outlet to the top of the tee
