Flourescent to LED
4 Oct 2019
Got an old 4ft fluorescent light in my utility room thats pretty much died. I want to get rid and put a LED batten up. My question is can i connect the new LED directly to the wires that the current fluorescent is connected to once i've removed it?
If it is just a "utility room", a LED (Fluorescent Replacement) batten may be OK.
Anywhere else, I would suggest a decent LED Panel.
They do look good, would struggle to fit a 5ft tho.
How would i know? The fitted florescent is prob over 20 years old.
If over 20 years old then will be magnetic ballast, does it have a starter? The starter is only used with magnetic ballast and a new starter is supplied with the LED tube.
Well actually it's not a starter with LED it's a fuse, but fits in same hole and looks the same as starter.
It does have a starter, think its T12 as opposed to T8 would that be an issue?
Look at the (minimal) documentation supplied with any fluorescent replacement LED tube.
(I recommend an Osram SubstiTUBE)
Mostly the replacement LED "tube" will tolerate being placed in series with any magnetic ballast but (usually) any such ballast may be removed (or shorted out) and forgotten about.
As ericmark wrote, "Well actually it's not a starter with LED it's a fuse, but fits in same hole and looks the same as starter."
There is usually a warning "sticker" supplied with the "tube" to be placed on the "fitting", warning others of the changes which have been made.
