In 2011, I had a new combi boiler installed to replace an old back boiler and now have concerns that the flow and return were mixed up. The existing pipework was untouched except for a short length of the main 22mm pipes from the back boiler. All rads except the bathroom have TRVs on them.
Story below, if you want to read it, but my question is.....if it is mixed up, what are the implications for the system. The water is entering the rads from the wrong end isn't it?
It 'works' but I have never felt is worked properly since the combi install. EG: Some rads stay hot, even when the TRV is turned right down, which I blamed on faulty valves. Some don't get hot when they should.
I realise I should get the fitter to come back, but after 5 years he wouldn't admit or remember doing anything wrong.
I can get the pipes at the boiler swapped over I know, but I can't help thinking that my investigations are flawed...I'm not a plumber or heating engineer.
Before I get someone out, am I correct in saying that the pipes that would get hot first are the 'Flow'? Is there another way to test the pipework, seeing as I can't visually check the routing under the floors without wrecking the house.
Story:
At the time as the boiler, two new rads were installed, to replace existing ones.
Since then, I have put in two new radiators myself, again just replacing old ones, so all I did was put the TRV on the same side as the existing.
I am now in the process of replacing another radiator for a new one and noticed that the return side pipe got really hot, way before the flow pipe, even though I just replaced new for old, same set up. Two rads downstairs at the end of a run dont get hot at all, but the 'Return' pipe does.
I've looked at as many pipes as I can see and the fitter has written 'H Return' on what I am convinced is the 'Flow' pipe. Following this pipe back to the boiler it does in fact go to the 'Flow' side, NOT the 'Return' as he seemd to believe. Firing up the heating makes this 'H Return' pipe get very hot, very quickly, so it clearly is the 'Flow' pipe.
Story:
