- Joined
- 15 May 2017
- Messages
- 21
- Reaction score
- 2
- Country
I'm not a plumber or tradesman.
I've just had a new Ideal logic c30 combi boiler fitted that replaced a very old Baxi system boiler. TRVs were also fitted.
I asked the installer which pipe was flow, and which was return (so that a magnetic filter could be added later). He said when looking at the boiler, the return was on the left. Flow on the right. He added a drain of to the left pipe.
However, when feeling which pipe gets hot first, the left does. The radiator pipes get hot on the lock shield side first. The user manual says left is flow.
It seems its backwards to his intention.
Could someone answer the following?
1. Does it matter?
2. I was told by chance that the TRVs they fitted (bulldog?) would work on flow or return side, but they fitted them on the side which had a "wheel". I guess the intention was the flow side.
3. Is the drain off affected?
Many thanks.
Dave.
1. Does it matter?
Many thanks.
Dave.
