Hi all, I have just discovered after 10 years , that the flow and return on my trusty worcester bosch boiler , are reversed. Quick fix is to set the boiler stat to 8 o'clock position and set the pump to max ie not auto. The 3 port valve is working correctly, hot water comes in at the bottom and is diverted to rads or hot water tank. I wonder if I could just reverse the pump, that would mean the 3 port valve sucking instead of blowing.
