- Joined
- 29 Oct 2004
- Messages
- 4
- Reaction score
- 0
- Country
Hi List -
I need to get a run of pipe from where the (hot water, 22mm) supply emerges at ceiling height, down a wall, to meet the exit point which is a stub of 15mm copper pipe at floor level leading through the wall to the kitchen beyond.
The run, from ceiling to floor level, is about 3 metres. It will be easier to dig out a chase for 15mm copper down the (brick) wall, but for some reason I'm worried about loss of flow and feel I should be using 22mm as far as possible.
From hot water cylinder to where the 22mm pipe emerges in the ceiling, is only about 3m, then I need to go 3m down the wall, to meet this 15mm pipe which then runs through the wall and sub-floor, about 6m, to the kitchen sink etc.
So, bearing in mind that most of the run is already in 15mm, am I going to notice any significant reduction in flow at the taps, if I complete the link in 15mm, as opposed to in 22mm...?
Sorry for the length of this post, hope it makes sense !
All views gratefully received - thanks in advance.
Kind Regards.
Kind Regards.
