Flow Rates Combi Boiler
B
Bodd
Hello All
I have a job that I m fitting a Combi boiler. the customer has can I fit a combi with a high flow rate
I intend on fitting the new Worcester Compact 32 Kw I think 12.9 Lpm
any one know of a better boiler with a highr flow rate.
not sure its worth it any way as getting.
Standing pressure over 2.5 bar. working prssure 0.5 (2 Taps ).
Bod
You might like to register for the combustion chamber section of the forum for more objective advice. But flow will be as pi important as pressure. If not more so.
As you must know, no combi is going to adequately service 2 appliances simultaneously.
I have applied to join.
Its a small house (tiny) Im looking for a good balance
I have a 30Si at home and shower still ok if somone else uses the kitchen tap.
It not going to be perfect but he will ask the question and I will give him an answer.
He's an ex gas engineer so he knows a bit.
He knows its only going to get out whats going in.
