Hey,
I have a bathroom vanity that has a shallow sink. We have ridiculously good flow rate here (on both hot and cold) so when the tap is fully opened the force of the water causes it to rise up the sink and over.
I've tried closing my isolators a bit, but the noise (presumably from the water force) is really noticeable through the isolators unless they're fully open.
Is a 'proper' flow reducer/restrictor likely to suffer the same noise problem, or, as they are designed to actually reduce flow do they not?
And what's a good one to get? I think realistically a 50% reduction would be needed!!!
Yes, I know I can just no open the tap as much... not so easy with young children around!
