I've recently moved and I'm trying to understand the pipe layout of the central heating system.
Just after the pump and the 3-way valve, the heating feed is connected to the heating flow return via a 15mm pipe with a stop valve. The valve is set to fully open.
I don't understand and am curious as to why there's a direct connection between flow and return like this and how should the valve be set ? Fully closed is my instinct, but then why install this pipework in the first place ??
I'm in the process of flushing out the system and then balancing the radiators, but I think I need to understand what this valve is for before going too much further.
