I am having problems getting my Kensal Flame gas fire repaired.
I have had two gas engineers look at it, one a family friend but to date with no success.
Try to keep it short but this is what has happened.
When pressing the on button to turn on the flue fan the house sockets would trip out in the main fuse board. An engineer was called and he said it required a new fan drive unit, (a unit that fits on the end of the fan shaft which when powered rotates the fan)
This was order and fitted, the fan would then power up but the fire would not light (no gas was being let through)
More parts were ordered, being a Solenoid valve and a pressure switch.
These have now been fitted and what I have now is a fire that works for about 30 secs. The fan starts when pressed, the ignition process starts as it should, the fire fires up - lovely warmth at last, then after about 30 secs the fan is heard to power down then the fire cuts out which it is presumably doing because it has detected the flue fan has stopped.
Any ideas?
PS the fire is about 6 years old and was fiited as standard to out Bovis house which was a new build at the time. Fire model is a Kensal Flame Premier and is made by Gazco
Kovo
Any ideas?
Kovo
