I may be wrong but it is my suspicion that all these people "callibrating" our equipment do nothing to it. That is they measure it's performance against a standard. I bet my bottom dollar they have no way to or knowledge of how to adjust it. The whole callibration industry is yet another leach sucking our blood.
If it needs repairing which it does send it for repair. If you send it for callibration you will pay for callibration and receive it back with a failure certificate.
If I were sending a Kane for repair i would send it to Kane.
Paul, I am concerned by your comments, who carries out the servicing and recalibration of you instrument?
the sprint v2 is overrated.
i want to smash it into pieces everyday. it beeps constantly and covers the display with a warning when it is low on charge but will last for more than a week on low charge, why cant it remind you just once then shut the hell up?
it often has no idea if it is being used for positive or negative gas pressures and will flash up a warning saying you need to change the test tube to the other port, when you do it flashes up the same warning with that ultra annoying trill. when you cancel this warning it again covers the readings with a warning within 10 seconds and trills again and again and again. what is the need for this warning? quite a few boilers start at 0mb then go to negative due to fan pressure then positve due to gas pressure, why can't they sort out the software so it ignores this? its not like i cant see the negative sign in front of the reading its highly irritating when you are trying to set up a boilers bp.
add to that the ludicrous size of the gas detector and its a pain in the a**e to use IMO.
Just how big is your gas detector? Is it the feathery yellow one that carps all over the dash board?
Tim
