Hi
New here so please be gentle with me.
Right straight to the point, i'm collecting the bits so that I can fit a new heating system before the old one dies, I've got 2 x 28KW gas condensation boilers to replace the old one, question is about the flue, the boiler will go in the basement and there is the existing chimney which is used as the present flue, but no flue liner fitted.
Q1. Do I have to line the chimney? (no fireplaces fitted)
Q2. Can I use plastic pipe?if so, any type, is soil pipe ok?
Q3. Hot gases rise so no problem with gases coming back through 2nd boiler if not being used?
Any recommendations would be helpful
