Hi, I have a 10ish years old BAXI Barcelona condensing system boiler which now needs replacing. The twin flue configuration is as far as I can see not standard. I live in a flat and due to the situation of the boiler and the distance to the outside wall, I have a flue that runs thro casing in the ceiling. the length of the flue is a approx 6m. The odd thing is that the flue dips down about 10cm straight down just before it comes to the outside wall than then comes horizontal straight out of the fabric of the building. I know this is done because I have a girder stopping the flue from coming out on an incline from the boiler.
My challenge, I can not drop the flue low enough to allow an incline to the outside wall without dropping my ceiling to an unacceptable height. I do not want to locate the boiler in my living room or bedroom, simply not a good cosmetic option.
Is there a condening boiler that will work with an (twin) flue(s) going up away from the boiler and then dipping? Anyone seen anything like this? Is the install legal?
I am desperate for help, no hot water or heating!
thanks in advance, G
