Please could anyone tell me what the current OFTEC recommendations are for condensing boiler flue terminals with regard to distances to property boundaries and also openings ie windows, doors, etc? Thank you.
If you download a manual for your boiler or any modern boiler
they give a diagram of positions covering all usual posibilities in a house and the separation distances required.
Sideways distances from windows etc. which are set by the maker and then distances in the discharge direction which are required to not create a nuisance or danger.
Generally a flue should not discharge closer than 2.5 m to your property boundary. Thats a figure usually worked to by Environmental Health and Building Control.
But it would be better if you explained your concerns to us!
You have told me exactly what I needed to know - i.e. the OFTEC recommended and intelligent flue terminal position is no closer than 2.5m from a boundary and 1m from doors, windows, etc in any direction to avoid danger and nuisance.
Many thanks to you all - knowledgeable members and a great forum.
