Flue restrictions,twin flue system
6 May 2009
Sussex
Does anyone have any ideas as to the possibilities for flueing a boiler from a cellar.i cant get the flue 300mm(200 mm max) above ground so normal flue not poss,cant go vertical.
Can you run a twin flue from a G/W ,through wall,elbow both ducts up externally,then elbow away from the wall and then terminals.
Have spoken to G/W technical guy but to be honest i dont have much faith that he knew what he was talking about.
By the way he said Yes..
Yes sorry glowworm.i spoke to them as i know there heat only boilers can be run as a twin flue system.
are you proposing to run some of the twin flue system outside? I don't quite get your description.
Yes.the max above ground i can get when exiting the cellar is 200mm,so i need to know if i can run the twin flue (air inlet and flue duct)up externally to terminate approx 2 meters high.
Can you not terminate air at low and snorkel kit up on gas or go back to concentric terminal with snorkel?
I'm pretty sure the answer to that is no. Never known a twin flue kit that allows external runs.
