I've a Valliant Ecotec boiler and recently had it serviced.
There are two plastic caps on the plastic ring that joins the boiler to the chimney flue. I guess they are for inspection or something? Anyway, I recently noticed water gathering below the boiler and when I checked one of these caps was undone and lying loose on top of the boiler. I'm pretty sure this is where the steam is coming from that is creating the water. The service engineer must have removed this.
Firstly, I assume I should screw it back on? Secondly, is this going to have been leaking Carbon Monoxide back into the room or just water?
The water has damaged the boiler cupboard so need to speak to the engineer about that too..
