Hi All
I have just had a Wocester greenstar 28 i boiler fitted. I have a question about the flue.
The flue comes through the bungalow roof.
I can see the flashing that fits into the tyles then a rubber gasket about 3 in long.
Then 3in of white flue,
before a joint then the rest of the flue is black.
A neighbour has same boiler and flue but no white showing and what appears to be a gasket around the area that is white on mine.
I have seen over 20 identical flues on our estate and not one has the white part showing at the bottom.
I have had someone from the company who fitted the system round and they said it's just that the flue was cut a bit long that is why the white bit is showing but it still would be ok and did not need altering.
Am I right to be concerned about this.
Hope you understand my descrition.
Regards J.
Regards J.
