FLUELESS FIRES
  • Thread starter expertgasman
  • Start date
E
expertgasman
9) FLUELESS FIRES- Do you fancy one?
Flueless fires have been discussed on this site a few times and the resounding advice given from Gas Installers is to AVOID at all costs!
These fires are attractive to consumers as they are 90% efficient as opposed others which are only about 70%. BUT....... As the products of combustion are not expelled up the chimney, these fires require a specific volume of ventilation to ensure their safe operation!
Flueless gas fires require correct installation and depend on :
A) Correct pipe sizing
B) Room Size
C) Ventilation
D) Gas rating checks
E) Gas Analyzing checks
F) Regular servicing
All existing Flueless fires MUST have an audible tone CO alarm installed in the same room to help to protect the occupants.
There have been a number of deaths attributed to these fires and you should bear this in mind if you are considering having one. :(
What utter nonsense! the only factually correct comment is the A-F list - which apply to ANY gas installation.!!
You CAN use steel wool for cleaning copper but a better job is to use the rough plastic stuff you get for scouring pans, which is available in decorators etc as it is inert and does not leave strands of steel to corrode. Don't use washing up liquid in push fits, it can degrade the rubber seal, use silicone lubricant,don't know if vasaline is any good or not?[/youtube]
i proably read this wrong aere u asking can u pushfit with gas
if so the answer is no
and if not then please rephase your comment
and you do have to use a flue gas anzser as part service and commsing the fire as its in mi and wqould not install one without co detector
If you are going to participate in a forum, it would be nice if you were to write in a mannner that is decipherable by normal people. Your post seems gibberish, and you seem to be responding to two people?
Re the FGA, I actually said tht the only valid comments were in the List , which includes the need for an FGA!
How did it get from a manufacturer with iso 9000 status getting away with sending out more than one faulty appliance scot free of a type I will never fit, yet the fitter got nailed to the wall, straight to cleaning copper pipe ?
Looney fitter, my last post wasn't aimed at you, as we were writing at the same time. I was reffering tp the other Loony, above you
then i would suggest if YOU are going to participate in a forum you read the whole thread :idea: :idea:
on account of its been split (badly)hence my comment as it now does not make sense :eek:
Kevin, I wasn't referrring to you, either. I was commenting on adlplumbing's post. I stand by my original point, which was that the FAQ post was largely innacurate.
Having said that, it was odd that Focal Point and BnQ got away scot free, but the fitter DID do the job wrong. He should have read the list above.
And have Focal point still got iso 9000 status, have they, have they Brian have they Brian, mmm, mmm, mmm (all said in Stewie's most annoying voice)
