I bought a Fuidmaster PRO71UK flapper valve to go in my plastic Fordham Sprite cistern without carefully checking the installation instructions:
http://www.fluidmasteruk.com/downloadable/download/sample/sample_id/95/
Part of the attraction is being able to re-use my flush lever, but Fordham (30 years ago ?) made the spindle in an unusual manner. It goes right to the back of the cistern and has a small vertical disc on the end which fits in a slot and so holds the spindle horizontal, at least that's what it look like (I haven't pulled anything apart).
So I don't have what Diagram 2 (aka step 13) in the instructions call threaded shank or hex-nut, so I can't easily clamp the bracket to the front of the cistern.
Any recommendations such as:
a) Glue, if so which
b) stainless self-tapping screw, above the overflow line
Thanks in advance for any replies (even those which point out that it says on the box "for professional installation only") and apologies for (I'm pretty certain) not inserting the url properly.
Cheers, Graham[/url]
