flush a combi boiler system for a diyer
7 Nov 2011
Tyne and Wear
i am thinking about cleaning my heating system out. i took a rad off the wall to replaster and it was filled with loads of black gunk. my heating dosent seem to be working as good as it did when i first moved in. ive tried bleeding them but still no good. all i can think of is that theres to much gunk in it. i was thinking of connecting a hose pipe to a downstairs rad draining plug and turning the filling tap on the boiler for awhile. will that flush it out or will it do something to the boiler. the make of the boiler is a volkra or something not sure of the model. thanks to anyone that helps and gives advice.
There is a video on Youtube which shows flushing out a heating system with a hosepipe. How effective that will be is a another matter, and if larger particles of rubbish are forced through the boiler there is the possibility of blockages which could be very expensive to resolve.
Another more likely option is to remove each radiator, take it outside and flush through with a hose, preferably hitting the rad with a rubber mallet at the same time to dislodge whatever is in there.
If they are really bad, you may find this causes the radiator to fail, however better if it does that outside than all over your carpet.
