Having a bit of a mare. 2 1/2 years ago we had a new bathroom & en suite fitted.
Last week the bathroom toilet started overflowing into the pan. The loo is a back to wall Roca against a built in cabinet .The cabinet is this
https://www.cityplumbing.co.uk/iflo-Aliano-WC-Base-Unit-Oak-and-Panel-500-x-380mm/p/767045
I popped the top panel off and no sign of the isolating valve so had to remove the main panel which was siliconed to the floor and toilet. After removing the silicone I was met with water, not much but once the panel was removed I found the flush pipe had been leaking from the cone so two issues.
That aside I took the whole lot out. It was a basic black plastic tank with a Macdee Wirquin
(Kara) 2" flush valve and a similar made fill valve. The overflow into the pan was caused by muck in the fill valve.
The flush was rubbish anyway and have since read a few bad things about Wirquin so I replaced both with Fluidmaster versions, all good, flush much better. I also re plumbed the isolating valve so I could access it from the top panel.
Onto the issue. The original flushpipe into the loo was clearly too short so purchased new plus a new flush cone (black rubber as recommended) . When I dragged it all out it was surrounded by loads of clear silicone. The intake to the loo is rammed with silicone. Needless to say I tried my hardest to remove the silicone but some still remains, I can't access it so am working back to front it at the loo is attached (and siliconed ) to a tiled floor.
So I tried the new cone and flushpipe and it leaked. However after a bit of manipulation its dry after multiple flushes but I don't feel happy, the cone isn't that tight either.
What would you do, hope it holds or remove and try and get all the old silicone out. I guess I'll have to remove the toilet so I can see what I'm doing - any recommendations for removing silicone ?
The alternative now that it appears dry for the time being is to say sod it and add more silicone or will I be looking at another leak weeks / months down the line ?
In your experience do these cone valves need a fair bit of manipulation to get a proper seal and will they work with old sealant fouling the inside or am I totally over thinking this ?
