As you go up the stairs to my loft conversion there is a false wood wall on the side of the light switch. At this moment in time the white light switch is just mounted on top of the wood sticking out several cms. I want to change it to a chrome light switch but flush mount into the wood.
Now my question is if I cut a hole in the wood then in order to mount the 25mm metal backing box it wont have anything to support it so will just fall. Is it possible to flush mount a light switch into wood/false wall and if so how
Many thanks.
Many thanks.
