flush not working
21 May 2010
Lancashire
:evil: the flush on the wc concealed system the button staying in the flush will not flush
You will have to get access to cistern to see what the particular problem is. There should be a panel that can be removed for access.
If its a problem with the button, check all the linkage to see if its correctly connected.
If this is not the problem im thinking diaphram, check to see if it has any splits or holes in it.
But yeah there should be a panal that can be taken out to gain access to the cistern for needs of maintence
