I want to have a flush gas meter box fitted in the new wall I'm having built for our garage conversion. Unfortunately there is an aco drain right across the front which needs to stay. I expect the gas inlet pipe cannot go up through the cavity and in to the box? So, what is the usual solution to this?
I expect it would look a little odd if the pipe comes up in front of the aco (about 5-6 inches away from the wall). Not only that, there is a risk it could be knocked or damaged.
Thanks.
Thanks.
