Long story short, I took a rad off the wall and flushed out a ton of sludge. Rehung and it's improved considerably but not completely. The back panel is now hot all along the bottom but the front panel is still cold along most of the bottom. Doesn't start getting hot until a third of the way up at the worst part.
The radiator is much heavier than I imagined (around 50kg empty) so to avoid breaking my back, fingers, and toes, I was wondering if it would be possible to flush from the top? I.e. remove the bleed valve, the blanking cap on the other side, connect water and drain hoses, and flush without removing the rad. Or will the flow rate not be enough to force out sludge from the top?
(the drain hose would be about 8m long unless I fire it out the adjacent window, which I'd rather not for obvious reasons)
