A few of my radiators have been playing up over the winter, and have been a combination of completely cold, and cold/warm at the bottom. The other 2 are/were fine (really hot). Anyway I took 3 of them off at the weekend and flushed them out in the garden with a hose. There was a fair amount of black sludge, but not excessive. I refitted the rads and all seemed well...but now the central heating system will not refill and replace the lost water.
My system is old school, and the boiler is a relic. The system is open vented.
I worked my way back and bled the rads - still wouldn't refill.
I checked the expansion tank ball cock and flow to the tank - both are fine and it fills fine (exp tank).
I have checked the valves on the down pipe from the expansion tank to the cylinder - all open.
Last night I drained the system and cut the supply to the expansion tank - hoping the remaining water would be drawn in - just to prove that there is a flow from the exp tank - still no water going in to the system. Now my rads are empty and I have no water in the system.
I think that there may be a build up of gunk in the pipe between the expansion tank and the cylinder, as there is a fair amount of gunk/weird sludge in the bottom of the expansion tank. I tried clearing the outlet pipe with a wire coat hanger, but still no joy.
After all of this...my question is if I link up a hose from my upstairs cold tap and and push any gunk through the pipe in to the system will this be ok (as in not damage anything?). I know that the pressure would be higher than normal for a system, so would be careful. I then planned to whack in some inhibitor, refill the system and then drain it next week. I really dont want to get the system power flushed as I guess it will cost a lot (£275-375?)? Does this sound about right? or is it a bad idea?!?
I need to get this sorted as we dont have an immersion heater, and cold water is starting to grate a bit now!
I am new to all of this and had never taken a rad off until the weekend, so if what I have done or am suggesting to do seems off the mark please shout out!
Thanks in advance
Matt
Thanks in advance
Matt
