Hi all,
I'm looking to add a couple of rads to my heating system (pressurised system powered by a 38kW Worcester-Bosch combi). Where I'm puzzled is what I do about cleaning out the swarf and flux when I'm finished. When I've plumbed anything before it's a simple case of blasting water through it and down the drain; with a boiler in the mix how do I make sure I don't clog up the heat exchanger? Is there a filter that catches anything big enough to be problematic?
The boiler was installed 3-4 years ago, and is in good running order (serviced each year by an approved Worcester-Bosch installer). The pipework for the ground floor comes down from the ceilings and also on the ground floor are draincocks on most rads and underneath the boiler itself.
