When adding a system cleaner (Sentinel X400) the instructions say to leave in, then drain which I understand but they also say to flush the system. I am not using a powerflush machine so could someone explain what this means. I took it to mean leaving the drain valve open with the cold feed to the F/E tank on so that water runs through the sytem - is this correct?
