I used some speedfit the other day.
I had to make a connection to the existing copper pipework.
I cleaned with wire wool the green staining and other muck for a couple of inches at the end of the pipe where I pushed the Speedfit connector.
I've just realised the green staining would have likely been residual flux left behind from years ago when the original copper pipes were welded.
So I am now concerned that the speedfit connection will be compromised as I've been reading flux is a big no no.
Is years old flux staining/residue on a copper pipe likely to cause issues.
Is cleaning it off with wire wool sufficient?
Should I replace with compression or check the fitting in say a couple of months for any corrosion?
