Wonder if anyone can shed any light on this.
I own a Flymo 330 Glider hover mower, the second example of this model I've had since moving to this house, which has a largeish lawned garden, in 2014. The first one was ditched after developing an horrendous vibration which didn't respond to any of the remedies I came across in online forums. I ran it without the blade to check for a blade fault (it didn't vibrate without the blade, so I bought a new one and it made no difference). I changed the blade retaining washer and bolt but again, no change. The only potential remedy I was aware of but didn't consider was changing the bearing, which I would imagine is not economically viable. Anyhow, that one went to the tip after about 18 months' service.
The second example has now started vibrating also, after just over a year of use. I've tried the things above without success, but today I added a second spacer to reduce the blade height and lo and behold, no vibration. I don't want to continue using the mower with two spacers because I prefer to leave the grass a little longer, but if I take the second spacer away the vibration is likely to return. Anyone have any clues as to what is going on, and whether there might be an alternative solution to adding that second spacer?
Thanks in advance.
Thanks in advance.
