I have a water tank which is insulated with foam but this means the airing cupboard above does not get warm. Could I cut a small area of foam from the top of the tank to let a little warmth out? The hot water is always VERY hot.
the amount of beneficial heat will be minimal to the cupboard however the loss of heat from the tank will drop the water temp and hold the boiler on longer therefore it will cost you more in gas, if yourwater is too hot turn the stat down and save fuel
The foam is put around the cylinder to hide the fact it is made of copper. Removing the foam will therefore show the foam and make it much more likely the cylinder gets stolen.
Indeed Part W para T line F of the building regs state ........ Wherefore a combi boiler is not fitted in a property a cupboard for the purpose of airing shall be fitted with insulation around about under and over it so that it`s thermal transmission shall be less than 0.01/wMsquared
