With this cold weather here I thought I would have a go at insulating the shed door.
My idea is to staple a layer of insulating foil on the inside then screw a sheet of foamed PVC over the top.
The foil will stick out slightly around the edges to act as a draught excluder as well as add some insulation to the inside of the door.
If this works I was then going to do the walls and roof.
Foamed PVC sheets are used in sign making but I wondered what people think of using it as a thin cladding?
Here is an example of the sheets I am thinking of trying http://www.plasticstockist.com/Foamed-PVC-Sheet/White-Matt-Foamed-Pvc-Sheet.aspx
Thanks for looking
Bern
Thanks for looking
Bern
