Foil Backed Plasterboard
DJM
4 Aug 2003
Surrey
Adding some more insulation in a loft conversion and therefore need to put up new plasterboard.
Any reason to use foil backed plasterboard rather than a separate waterproof membrane and standard boards?
No there is no requirements or advantages to using foil backed boards, rather than using a separate vapour check barrier and standard plasterboards.
  • Thanks
Reactions: DJM
Thanks, I'll stick with a membrane then as it's much cheaper than foil backed.
