Following the revelations about Windows XP Help & Support system having a problem that leaves it vulnerable to attacks, until Microsoft can come up with a fix, it is advisable to turn off the Help & Support part of Windows XP.
Most users have hardly ever used it so it will not be missed until a fix is available.
To turn off (disable) Help & Support and stop it from starting at boot up:
Click Start -> Run -> in the box type services.msc -> OK
The Services window will open, click to maximize it if you want to see it all.
Scroll down to Help and Support.
Double click Help and Support.
In the window, click STOP. Then click the Start up Type -> select Disable
Then click Apply or OK and close the windows.
Reboot. You may get an error message after bootup:
“Windows cannot open the Help & Support . . . etc.” If so just click OK or close it.
As the title says this is for Windows XP ONLY
I posted this here instead of the Software Section because not everyone looks in there, so, Mods, please leave it here.
dave
dave
