Forced Air Heat Working DHW cold!
7 Dec 2009
Fife
I'm a bit new to this but I think I have a gravity feed DHW system.
I have forced air heating, which still works, but no hot water.
When I turn on the hot water on the boiler I hear a click but no other noise and the pipes leading to the hot water tank are cold.
The pilot light on the boiler is on.
When I removed the cover to the boiler there does seem to be a pump of some sort but not the normal big red one you often see on central heating systems.
Any ideas how I can find out what might be wrong with this system?
OK, after a bit more research I have found out the water heater is a Johnson and Starley JANUS6.
AND the pilot light is out! (I was looking at the air heater before - didn't realise they were 2 separate things).
Got the manual from J&S website (thank you J&S )
http://www.johnsonandstarley.co.uk/...omesticwaterheating&doctype=User Instructions
However I have followed the instructions and cant get it to light!
I'm not sure the ignition is producing a spark, what can I (safely) do about this? (Use a match?)
Yeah, that worked :D
Is it worth trying to replace the piezo ignitor?
Guess the other option is to keep a box of matches handy!
He was only asking a free question!
Tony
