hi all,
im looking for a bit of guidance on the ford escort encore 97.
for a while now the car has seemed to have a problem of lack of power like the clutch was slipping. had cluctch changed but problem continued inimitantly, the fault developed a bit more and seemed like it was missing every now and again, now the fault more where the car breaks down.
the symptoms are as follows
on tick over no fault apparent ticks over fine
during transint engine misses bounces around
on attempt to restart engien fails bubbles abit as it trys but fails to start.
on leaving the car to settle engien restart and ticks over fine again.
as for info purposes, car had exhaust replaced some years ago, mechanic put oxy sensor in vice to undo it instead of puting exhuast in vice after which the symptom of lack of power first occured.
been to garage who found a fuel leek blamed that and repaired it but car broke down following day, garage wants it on machine but fault lays in transit and ticks overs fine so machine proberbly wont pick up on fault.
im thinking oxy sensor but need proffesional opinions first as the car is now turning into a money pit.
cheers
terry
cheers
terry
