Hi. I have a 1999 Ford Escort Flight Estate 1.6 Zetec engine
Three problems with front brakes. I have replaced pads, disks and calipers
1) On a frosty morning, when I brake, the front brakes lock on and take an age to unlock. Turning off engine, depressing brake pedal hard and starting engine often helps. Or just waiting 5-10 minutes
From the boards it looks like this is:
a) water in the brake fluid freezing
b) faulty front brake hoses
So I will replace the fluid and the hoses
2) Driving along, not touching the brakes, the front brakes progressively come on and bring me to a grinding halt. This was very alarming on the M1 the other day! Solution as above, but what is the cause? Master cylinder? But how?
3) Other times I can be driving along and I notice that the brake pedal rides high - only needs a touch to bring the brakes on. That is a warning sign that the front brakes are going to seize. Solution as above, but what is the cause?
Any suggestions gratefully appreciated
