ford escort
25 Jul 2014
Kent
I have a 95 ford escort have all lights apart from normal front driving lights changed two stalks they are saying fuse box need help asap
Did both faults occur at the same time and do any of the headlights work?
Peter
The Escort is notorious for allowing water to corrode the fuse box area......if there's evidence of rust there, look no further.
John :)
yes side lights work full beam work just not driving lights heater blower a while back lights worked intermittently now just driving lights all together can get side lights and full beam though
It's possible that you have a relay fault, but the fuse box has many soldered joints that can give problems too.....personally I'd hunt down a garage that specialises in electrics, and see what they say.
John :)
I went to a auto electrician they said most likely fuse box all fuses checked they are ok had new stalk fitted was worried about doing fuse box if not that
