Ford Fiesta screen washers
26 Nov 2005
West Midlands
Hello,
Im new here and Ive got a problem which Im guessing is dead simple, but i dont know how. Dont necessarily want to take things apart if there is an easy solution.
Ive got an R reg Fiesta and my screen washers are not producing the liquid. The motor runs, the bottle is full (and not frozen). i get a little dribble and then nothing. Anyone got any ideas? (Not a leak because bottle still full from when i filled it up). It applies to the rear too.
Tried it breezer. still the same. It occurs to me that since i live in a hard water area that there could be some liming up? However i always use a screen wash.
pull the pipe off that goes to the nozzle and try again, or have you done that already?
Cant remember if it's the same on a Fiesta, but on some cars where the washer pump fits into the reservoir, it is inside a little rubber washer/filter.
These do get bunged up esp. in hard water areas. We always used to pull them out and cut the bottom cpl of mm off of it and refit.
cheers
CJ
