hi, my daughter has just brought a 2002 ford focus hatchback and the main key will not work in drivers door. it will work in passengers door and open central locking. what can I do to fix it?
as far as I know the lock has not been changed. the key turns in the door but won't open. when I took the key fob apart to change battery there looks as if there is something missing in the chamber thing....
The rear of the door lock should be connected to the locking mechanism via a connecting rod, Remove the inside door cover and check if it has come adrift.
