Recently I have noticed some drips of oil coming off the tray under the engine, noticeable on garage floor
Regular oil changes with good oil are essential on this engine.Yes, I am Def doing that.
By the way, on another subject, I have read bad things about the cambelts on these engines , I think they're semi immersed in oil, prone to snapping and should be replaced at 8-10 years at over £1000.
Any comments, thanks
Yes, the wet belt requires replacement at 10 years. A big job costing more than £1000 at a garage. Don't use anyone to do the job who has not done it before, it is much more complicated than a normal cam belt change and requires several specialist tools. It would be best entrusted to a Ford dealer. There are actually two separate wet belts, one to drive the cam shafts and the other to drive the oil pump. I don't think that there is a specified service interval for the oil pump belt but if either belt fails the results are catastrophic for the engine.Yes, I am Def doing that.
I've known of 2 engine failures down to the oil pump belt failing. Both had poor records of oil changesYes, the wet belt requires replacement at 10 years. A big job costing more than £1000 at a garage. Don't use anyone to do the job who has not done it before, it is much more complicated than a normal cam belt change and requires several specialist tools. It would be best entrusted to a Ford dealer. There are actually two separate wet belts, one to drive the cam shafts and the other to drive the oil pump. I don't think that there is a specified service interval for the oil pump belt but if either belt fails the results are catastrophic for the engine.
Using the wrong oil, leaving long periods between oil changes or using an engine flush are all things that can significantly reduce the life of these belts.
