ford mondeo keys
26 Dec 2005
freind of mine close the bonnet with the keys in side theres no way of openning the bonnet cause u need a key its the ford new security lock system,please can any one help got any ideas is there anyway we can open the bonnet with no key think it maybe electrical anyway of shorting it out to open bonnet. thanks
both keys inside???? they were attached together????? tut tut. Could you lift the car and reach up inside?
tryed that no luck,no spare key.need help big time
Try nearest ford main dealer take registration doc & i.d. They may be able to obtain key no. or hopefully new key.Only other way is yank off fuel cap with stilsons, take cap to locksmiths, they can make a key that will open doors.However this key wont start engine (no chip)
Depends if the fuel cap has the same number of wafers as the door lock. Best bet is to phone a mobile auto locksmith, who will be able to do the opening at your vehicle - saving any damage. Don't let anyone near the vehicle with a drill - this can be opened non-destructively.
You may find it is on the same fuse as the central locking and if you say it's electric then removing the fuse that feeds it will or should revert it to manual operation. You can then retrieve your keys. Ask local dealer of Fords but try first as they might be looking for work.
sorted guys removed door lock and took it to lock smith for key making.all good.
