I started a garden wall a couple years ago and not sure if I should have put in an expansion joint.
The wall is 4 inch blocks on the flat, I left it just below ground level and put expansion joints every 6 meters.
However at the corner I didn't place an expansion gap so effectively there is 6 meters to the corner (90deg approx) then 6 meters out from the corner.
Or 12 meters of wall length with a corner in the middle with only expansion gaps at each end.
Does this require an expansion gap/movement joint and if so how close to the corner should it be and its it ok to start a new joint when the lower section of wall below ground level doesn't have the joint in it too foundation level?
Thanks.
Thanks.
