This is my first post.
My down pipe and waste pipes over shoot the drain when the flow is anything more than a trickle. I've been told that I need to build up a couple of courses around the drain. I have dug out the surrounding soil right down to the clay (about 2 feet) as it was mashed with crap from the waste pipes.
I'm worried that if I filled the hole with fondation it may crack the drain at some point when it settles.
Should I put my fondation at this depth or refill with new soil and put the foundation nearer the surface?
Should I also leave a small gap between the drain and the foundation to avoid cracking?
What's the best mix for this type of foundation?
Many thanks in advance
Knightshaft
Knightshaft
