Hi, I'm just starting a brick shed build and I need a little advice for the foundations.
The brick shed will be 30m2, roughly 4.50m(w) x 6.50m(L) x 2.50m(h), cavity insulated wall with brick and block and a flat or slightly pitched roof. The ground consists of 0.42m of top soil in which it goes into pure compact clay at that depth, which I can push my thumb into with a lot of pressure but it only slowly sinks into the clay. The clay feels slightly damp but not saturated.
What depth and width should I be looking at to dig for a trench fill foundation to support this? Rebar recommended or fine without? It will be built right at the bottom of the garden away from the house if that contributes to any replies. I presume a strip foundation wouldn't be advised due to being on clay?
I presume I won't need rebar but if I can get away with not digging as deep if it is used, i'd prefer to add rebar as I'd like to mix up the foundation myself but currently, it's looking like the job is too big to mix it and premixed might be the way to go to get it laid in one day.
Any help and advice is appreciated, thank you
2 holes dug so far to see what ground i'm dealing with.
