I'm in the process of buying a building plot and I'm more than likely going to be having a timber frame construction.
I have been told that it only needs a raft/slab foundation, but I am not familiar with this process.
I have seen pictures, (there is a side profile attached) and realise that the outer perimeter has to be lower to act as a cavity tray, but I'm not sure what the setup is to be able to form this.
You need to give alot more information,ie. type for ground your founding into? As well as dimensions, storeys, as said above etc etc..
But given basically you strip out the topsoil and a good 150-300mm below, put in type 1 well compacted subbase, blinding, dpm, then some steel rebar to span soft spots and concrete.. job done..
But if you have heave suseptable clayie soil then you are better off with pad/tbeam rather than rafts..
Also consider services when planning rooms.. or put in a floating floor..
Precast concrete beam and pad foundations can be an option.. but yes raft is the most common.. cant remember the companies that do the precasts sorry..
Can be done in one go but you may not get a good surface on the lip.. might be simpler to do two pours..
