- Joined
- 1 Mar 2005
- Messages
- 75
- Reaction score
- 0
- Country
I have a wooden garage at the bottom of my garden 6m x 3m approx. resting on a bed of either soil or hardcore (or a mixture of both). Needless to say the plywood floor is rotten and the whole thing is beginning to sink into the ground.
The garage fronts onto a side road, and the rest of the garden has been properly paved and concreted as I have lifted a section to put down some grass.
I plan on bracing and jacking up the whole thing so I can put in a concrete floor.
I'd like some advice if I can do the following, or if there are any better alternatives:
Can I put a strip concrete foundation in of 150mm deep by 150mm wide? (on a 150mm bed of hardcore).
Then I plan to replace the rotten wood and sole plate, drop it down and attached to this foundation after fitting a DPM gasket.
Then put in a 100mm slab using these strip foundations as the perimeter.
I reckon I'm capable of the shuttering/bracing & lifting bit, (Although it's easier said than done) it's more the foundation and doing the concreting in 2 shots I'm guessing at.
Thanks in advance for any advice....
