That might be better for him.
Did he plan on having a proper raft designed with an edge beam, or just plonking a bit of concrete down at some undetermined random depth and hoping for the best?
His words where I park my pickup on 6 inches of concrete for years no probl so 2 skins of brick won't be a issue .
h. he.showed Me a photos of garage base he done , it was shuttering then hardcore,then sand & membrane and then concrete ,..he said I could have kingspan in my base if required ..
Damp prevention detailing is important with any raft, particularly at the wall/ floor junction. Does this builder have any proposals for that?
Whats a stepped arrangement ..there is a large horse Chestnut tree about 18m awayDamp arrangements on a raft are awkward.
Technical diagrams often show a stepped arrangement - perfectly doable, but needs shuttering to form.
More importantly what is your ground like and are there trees nearby
Ground is pretty solid
in which case a trench foundation might be easier and the damp arrangement is simple and quite fool proof
why do you want it in brick?
If its cavity construction the wall is at least 250mm thick
